1. Are the copper washers under the head bolts reusable if annealed or do they need to be renewed each time?
2. What do the 6mm bolts in the cylinder head do ? They look a bit weak to actually do anything!
Steve
A Couple of Questions
- wheelysteve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- wheelysteve
- wheelysteve
Steve, always make sure the surface of the copper washer is smooth and without marks which the oil can track. Beware of outside dia undersize washer often available on ebay (not that you can't use them it's just...!!!). Always anneal to cherry red & quench if re-using.
Note: You only need the copper washers on the four outside, I'm pretty sure early Z1's had copper washers under all 12 head nuts.... Now only 4 required.
10 washers for £3.00
22.3 x 11mm available here;
http://www.ebay.co.uk/itm/Metric-Copper ... 20f9ff6a4f
Users browsing this forum: zapo and 60 guests
