Any previous experience on summink that works, gents
LOCTITE - "Heat Resistant" for cylinder head?
I'm after some hi-temp LOCTITE (or similar) to lock the M10 grub screws in the cylinder head on me Z1000. I've drilled & tapped the air emission passages and want to fix them in place - air tight & secure
Ta.
Hinckley wrote:Loctite 641 would be adequate.
What about temperature - was thinking needs to be above 200 deg C ?
Colour: Yellow
Service temperature range: -55°C - +150°C
Tensile shear strength in N/mm: >6.5
Thixotropy: No
Viscosity in mPa.s: 400 - 800
Fixture time steel: 25 min
Maximum diametrical clearance: 0.1mm
Pack sizes: 10ml, 50ml, 250ml
If you never want them to budge again I have a spare small tube of 648 that you can have if you PM me your address. 648 is good to 180DegC which might be enough?
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627682305
Coose wrote:If you never want them to budge again I have a spare small tube of 648 that you can have if you PM me your address. 648 is good to 180DegC which might be enough?
Thats very kind of you lad
Hinckley wrote:I use it for securing bearings in cylinder heads, gearboxes and axles, also for retaining bushes in power valves and valve guides - never had an issue - have to heat them with a naked flame to remove them.
You can go up to 638 or 648 180°C or 278 +200°C.
Okay, ta. Don't know how hot a cylinder head gets in that area (or any other area TBH)
