Z900 plug caps
csnurney
Z900 plug caps
#1 PostAuthor: csnurney » Thu Jan 10, 2008 11:28 pm
Hi,does anyone know what is the correct plug caps and what angle they should be to fit my z1a.Is it still possible to get them.
Regards Chris. :wink:
london calling
#2 PostAuthor: london calling » Fri Jan 11, 2008 6:53 am
Is it the original type of plug caps you're after??
Jack
csnurney
#3 PostAuthor: csnurney » Fri Jan 11, 2008 1:37 pm
Hi, the original metal caps would be nice.Should these be nippon denso,because someone is selling a set on ebay and i don`t know if these are correct for a z1a.Should the inner cylinders have a straight cap,the outer cylinders have something like a 120degree angle on them.I have 45 degree ngk caps at the moment,just looking for something that looks better.Seen loads of different pictures of z`s and some have red ngk`s,black plugs.The ones on ebay the reserve looks to be over ?100.
Thanks Chris.
Can anyone advise me on the best route togo and where to get some caps from.
bedlow1
#4 PostAuthor: bedlow1 » Fri Jan 11, 2008 2:43 pm
the metal ones with the grey shanks (pictured) that i am selling on ebay are 100% correct for UK model z1,z1a,z1b.and z900 these are No longer available
The later uk z1000 metal ones had a black shank but were still a simular shape with a larger end rubber, these are still available from kawasaki.
And the the yankee bikes had all black non-metal ones that had the 2 outer ones angled slightly and the inner ones were straight.
beware A lot of the metal ones currently being sold cheap on ebay are intended for snow cats and chain saws!!!!
hope that helps!
1972 Z1 Euro Spec
1975 Z1B UK Bike
bedlow1
#5 PostAuthor: bedlow1 » Fri Jan 11, 2008 5:01 pm
kl
1972 Z1 Euro Spec
1975 Z1B UK Bike
