Poss,fuel problem
KEVMACH4
Poss,fuel problem
#1 PostAuthor: KEVMACH4 » Sat May 09, 2015 5:08 pm
Hi,z1started to run like shit,seems like fuel starvation. So pulled both pipes off carbs turned tap on and fuel ran from 1 pipe, should it run from both fuel pipes same time, Wonder if tap sucking air in.
#2 PostAuthor: PAULJAC47 » Sat May 09, 2015 5:52 pm
Whats the bike?is it a double feed tap or main and reserve?
KEVMACH4
#3 PostAuthor: KEVMACH4 » Sat May 09, 2015 6:13 pm
1 main tap with reserve, 2 fuel pipes of it , it's a z1 a 900' standard
#4 PostAuthor: chrisu » Sat May 09, 2015 8:30 pm
should run from both
one side feeds carbs 1&2 - the other 3&4
KEVMACH4
#5 PostAuthor: KEVMACH4 » Sun May 10, 2015 5:09 pm
As I thought should run both, got another tap ,so might give that a try, thanks
Users browsing this forum: No registered users and 95 guests
