Z1 Fuel tap
Z1 Fuel tap
#1 PostAuthor: ADRIAN H » Mon Nov 02, 2015 7:49 pm
I have bought a fuel tap repair kit from Z-Power. Has two rubber gaskets and two O rings in it. O rings are 18mm dia, and 14mm dia.
14mm dia goes on the fuel tap itself, according to part list.
But where does the 18mm O ring go ?
Thanks in advance, for any assistance received.
Adrian (feeling confused).
#2 PostAuthor: ADRIAN H » Wed Nov 04, 2015 1:10 pm
Problem sorted. :D
Apparently the Fuel tap repair kit has two O rings as the kit is used for different Kawasaki Fuel Taps, (some using the 18mm O ring).
So on the Kawasaki Z1B - I do not need the 18mm O ring.
It`s a freebee. :lol:
Users browsing this forum: No registered users and 76 guests
