Steady Jim.
What are people using to control end float on swingarm foward pivots?
On the J it had a steel cross tube (steel arm) and it just used to carve a circle in the inside of the frame.
New arm is alloy (ZR 750) but has no control over end float.
Consequently; the rubber covered steel backed grease seals, either end have now lost their rubber coating and play is around 2 - 3mm with a bit of a clunk!
Looked at the three piece thrust bearings but a minimum of 9mm needed each side so a bit of a faff getting it all machined away.
http://shop.marksman-ind.com/3-part-thr ... -403-c.asp
Axial thrust
Axial thrust
Users browsing this forum: No registered users and 82 guests
