bone jarring forks
wayno
bone jarring forks
#1 PostAuthor: wayno » Wed Aug 17, 2016 1:21 am
when out today when riding over a dropped kerb,the front forks gave a bone jarring knock, felt as if the front tyre was very low and hit the rim (first thing I checked), could not enough oil or too much cause this?
tlc
#2 PostAuthor: tlc » Wed Aug 17, 2016 6:05 am
Too much oil certainly could.
Stick a cable tie around the fork and see how much travel you have.
wayno
#3 PostAuthor: wayno » Wed Aug 17, 2016 9:27 am
You mean when on stop and rock on the front brake or while riding and brake hard?
tlc
#4 PostAuthor: tlc » Wed Aug 17, 2016 4:25 pm
Many years ago I tried raising the fork oil quantity by 45ml.
I then bought a tool to take it back out again.
From memory as standard I had about 3 or 3.5 inches of movement but with the raised level only 1.5 inches.
You really need to stomp on the brakes to find out exactly how much movement you've got.
#5 PostAuthor: Pigford » Wed Aug 17, 2016 5:04 pm
Eat a few more pies :wink:
wayno
#6 PostAuthor: wayno » Wed Aug 17, 2016 6:08 pm
Been reading around the web and found talk of hydrolocking, possibility? As i dont think it is bottoming out as i was only doing 3 or 4 mph at most.
