Oil Cooler fitting
steve bowdler
#16 PostAuthor: steve bowdler » Tue Oct 04, 2016 8:33 pm
I thought Debben did a longer cable ?
#17 PostAuthor: chrisu » Thu Nov 17, 2016 1:23 pm
bit of an update to this.
I'm putting a 13 row cooler on my Z1R and bought one with the 'standard bracket.
Yes it was too low and fouled the tacho cable. I've made a plate with a 50mm offset to shift the cooler up by 50mm from the existing holes. Works a treat and hidden by the cooler so you don't see it.
Oil lines in from the top. Might have to change my Z1 now.....
Fred the Zed
#18 PostAuthor: Fred the Zed » Thu Nov 17, 2016 5:15 pm
chrisu wrote:bit of an update to this.
That's essentially what my plan is too. Thanks for the update.
Fred
Paid Up Member
