calipers
royboy
calipers
#1 PostAuthor: royboy » Fri Sep 30, 2016 6:27 pm
hi all can the front calipers on z900 a4 be changed i.e left put on the right side using the floating braket from the right caliper put into the the left caliper so it sits right on fork leg.
CAT3
#2 PostAuthor: CAT3 » Fri Sep 30, 2016 9:19 pm
Yes, it's just the mounting brackets that make an assembly left-hand or right-hand.
Garn 1
#3 PostAuthor: Garn 1 » Tue Oct 04, 2016 7:45 am
RoyBoy, agree with Cat3, you will need to spot-face the mounting bracket where it connects to the forks (i.e. get rid of the rounded surface to ensure a snug fit). There is enough meat on the floating caliper to do this.
Note~ if your converting a Kz900 to twin disks the original single disk is much thicker. Also, you will need a 5/8" master Cylinder to make it work effectively.
royboy
#4 PostAuthor: royboy » Fri Oct 07, 2016 11:07 am
thanks all
got hold of a left hand caliper put righ hand bracket in jobs a gooden.
thanks again royboy
