misfiring a4
hiroz
misfiring a4
hi there,
after finishing the restoration of my z900a4 it has a flat spot problem,
first time up the road between 2000 and 3500 revs it splutters and misfires
like its dropping onto two or three cylinders but when it reaches 4000 revs it pulls like hell.
can anyone throw some light on the problem.
hiroz
misfiring a4
Hi guys,
i had exactly the same symptons on my zx7r last week. I had replaced the plugs.....turned out to be a plug breaking down....at low revs it ran on three...as soon as i opened the throttle more, it pulled through it. I don't know whether it has any bearing on this problem...but it could be a plug breaking down.
Scott
Scott
If you've just put it all back together I'd say it could be any one of a number of things!
I'd check ignition - standard points? - did you fit new condensers? - coils okay?
Also, obviously, carbs. Did you clean them all out?
Cheers, P.
Cheers, P.
1976 z900 A4 -- Now, with a little help from Wiseco and Steve Debben, it's a 1048 with rs34 flatsides
hiroz
MISFIRING A4
the bike has a new dyna s ignition fitted, new coils from z power although i have a brand new set of dyna coils to fit if necessary has anyone had any experience of running with dyna coils fitted are they well suited or not . so engine has been timed and auto advance is working perfectly.
must be carbs i hope !
Iain marshall
