UK Z900 rear wheel removal
Andrew_s
#1 PostAuthor: Andrew_s » Mon Aug 21, 2017 1:08 pm
Once the chain is disengaged and axle bolt removed do I simply push the wheel forward and remove it on the tilt to get it past the long rear mudguard to remove the rear wheel from a UK Z900 - or is there a technique I need to know?
Andrew
Current Bikes:
2023 R1250 GSA
Re: UK Z900 rear wheel removal
#2 PostAuthor: z1bman » Mon Aug 21, 2017 3:35 pm
tilt the wheel & it will come out from the brake side
Andrew_s
#3 PostAuthor: Andrew_s » Mon Aug 21, 2017 4:21 pm
:up Many thanks - couldn't see how it could be more difficult than that, but you never know!
Current Bikes:
2023 R1250 GSA
Users browsing this forum: No registered users and 83 guests
