Does anybody know the approximate power increase when using the v&h 4-1 exhaust and wiseco 1045cc big bore kit?
From a restoration point of view the big bore kit was the only practical solution to a seized engine and 4-2 exhausts are like hens teeth. Each of which has to increase power output.
Any ideas?
Power changes Z1000
Re: Power changes Z1000
Well set up with 28mm carbs, 80bhp (at the wheel) should be realistic, baring in mind most std bikes are around 65bhp. Add decent carbs, cams and flowed head = +100bhp easy enuff.
scarebus03
- new poster
Cheers for that Pigford
