Hi folks just a quicky 're fork oil refill on a 900 A4.
I haven't got myself a manual yet so I need to know the oil capacity for each leg and the recommended type used. The legs aŕe off the bike , so what is the best method to use for refilling , i take it you remove the top leg bolts and refill from there. Paul.
Fork oil????
Re: Fork oil????
yes - just take the top cap off and tip old oil out.
refill with 175cc of 10w oil or 15w if you want it a bit stiffer
Re: Fork oil????
You may find it easier to re-assemble once your stanchions are clamped back into the yokes, especially if the springs take some compressing when refitting top fork nuts
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Fork oil????
Thanks both. Good advise.
Users browsing this forum: Google [Bot] and 75 guests
