Mikuni RS34 Float Height
Julian_Boolean
#1 PostAuthor: Julian_Boolean » Mon Dec 04, 2017 5:01 pm
Whenever I put my Z on it's sidestand I get some fuel coming out of the carb overflows, making me think my floats are a little high, they're set to what Mikuni recomends (18mm I think) what float height sre other people running on Mikuni RS carbs?
Re: Mikuni RS34 Float Height
#2 PostAuthor: Al » Mon Dec 04, 2017 9:19 pm
I cant actually tell you the float height. Confronted by a similar situation, i bought a new 17mm alloy plug for the float bowl, drilled it, crimped a short length of copper pipe into and attached a length of windscreen washer tube. It wasnt enough for me to set the floats because i wanted to set the fuel heights when running. With the throttle set at about 1100 RPM i have the fuel level 3 or 4 mm below the float bowl gasket face. As per my old CV's!
That does not help really does it? Bought the float bowl plug from Allens Performance.
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Mon Dec 04, 2017 10:15 pm
Cheers Al, it helps because I now know where to get the plug from, I knew this was the proper way to do float heights but was hoping to avoid doing this.
KWACKERZ1
#4 PostAuthor: KWACKERZ1 » Tue Dec 05, 2017 2:22 pm
http://www.allensperformance.co.uk/carb ... ght-chart/
Allens web site has most info you'll need. If not ring them and ask they are grumpy but knowledgeable. (bit like Al :D )
#5 PostAuthor: ZedHead » Tue Dec 05, 2017 2:36 pm
KWACKERZ1 wrote:http://www.allensperformance.co.uk/carb-kit/carburettor-float-height-chart/
All RS are 17mm float height according to this
Users browsing this forum: No registered users and 76 guests
