Start Button
Start Button
The start button on my z1000 has broken and fallen off - ordered a replacement from ZP and see it has a lip so assume you need to access from inside - How easy is it to access to replace ? Cheers all.
Re: Start Button
easy Disconnect cables from carbs remove whole assembly and undo a couple of screws slide out, slide new one in, takes longer to do all the other stuff than it does to replace the button.
- 8 Valve Mark
Re: Start Button
keep a wee 6/7"mm screwdriver handy to compress the buttons' spring n wiggle the new button in, release the spring.. done. I
- ZedHead
Users browsing this forum: No registered users and 107 guests
