Hi has anyone used the z power all in one gasket kit 75.00 pound, do they stand up to the job or is it genuine gaskets is best? Just doing a top end rebuild rings and valves etc
Cheers guys
Genuine or pattern gaskets
Never ride faster than your guardian angel can fly.
Re: Genuine or pattern gaskets
Gen if you can afford it,but Vesrah are ok,just dont be tempted to use the included valve stem seals or cam tunnel o ring thingy,would always use gen head gasket as well,been there T shirt etc.
Cheers Paul thanks for the advice
Vesrah source the same gaskets as supplied as OE from the same manufacturer
Thanks guys I've ordered a mix of genuine and vesrah also the Viton valve stem seals
HI nail
you've made the correct dicision! Vesrah , original and viton, a great team!
The best of both worlds!
