z1B disc query
- warren3200gt
z1B disc query
Gents, what disc should be on a Z1B as standard. I think its 296mm dia but what was thickness new? 7mm? and 4 bolt?
if that's all correct anyone got a used one they would sell?
PUM 488 June 2023
Re: z1B disc query
7mm standard thickness 6 bolt mounting
- warren3200gt
Re: z1B disc query
Thanks, which other bikes had the same fitted? I think 650's had 320's or 296's depending on model but not sure if they were all 4 bolt. A4's were 320's /6 bolt?
Just want to be sure when I go for a trawl.
PUM 488 June 2023
Re: z1B disc query
296mm diameter. z900 a4 uses a 4 bolt disk
Re: z1B disc query
5MM It twin discs..
Re: z1B disc query
z1bman wrote:296mm diameter. z900 a4 uses a 4 bolt disk
This - A4 is 4 bolt. Z1, Z1A and Z1B all 6 bolt
Re: z1B disc query
H1 & H2 Triples also 6 bolt
- warren3200gt
Re: z1B disc query
Ok, so plan b, I have a 650 4 bolt hub which I can swop in but would then need a 296 / 4 bolt disc. Which bikes had em? and has anyone got one they are willing to sell?
or does anyone know if the swept face internal dia is the same on all the discs? Thinking it might be easier to get a 320/4 hole and turning it down to 296.
PUM 488 June 2023
- warren3200gt
Re: z1B disc query
Confusing myself now. So just for clarity and confirmation with Z1B forks and calipers which disc size should it be ? 320 or 296?
This its what I'm trying to achieve, I currently have A4 forks, wheel and disc's / caliper. I have a pair of B forks and caliper which I want to swop in. The hub is 4 hole so do I need 320 / 4 or 296 / 4 disc?
PUM 488 June 2023
Re: z1B disc query
Kawasaki Z1B - should have a 6 hole front hub, discs should be 296mm with 6 holes.
Standard single disc - 7mm thick.
If going for twin disc each should be 5mm thick.
6 hole discs also used on H1 and H2.
- warren3200gt
Re: z1B disc query
Right, so I should be able to swop a4 forks out, fit b forks/caliper and use my exisying a4 wheel and a4 296 disc. ? Reason Im unsure is because caliper mount lugs are so much lower on b forks.
PUM 488 June 2023
Re: z1B disc query
Z1B calipers are different to later model calipers.
If you want to use Z1B forks you will need Z1 - Z1B calipers
You could buy this kit from Z-power.
http://www.z-power.co.uk/brake-kitdouble-z1-h1-h2
- warren3200gt
Re: z1B disc query
Yep, I know, I already have a b caliper but the mount bracket difference for it doesn't look enough to compensate for the leg lug difference. Just making sure I have the correct usable bits to hand before starting the task.
That kit is for 6 hole discs, I'll be using a 4 hole hub with a 4 hole 296 disc.
PUM 488 June 2023
Users browsing this forum: skinnyZED and 251 guests
