Z1000H fork oil level
alfie1
#1 PostAuthor: alfie1 » Sun Aug 05, 2018 9:58 am
Hi can anyone tell me the correct amount and type of fork oil needed for a Z1000H? Per leg?
Many thanks
KWACKERZ1
Re: Z1000H fork oil level
#2 PostAuthor: KWACKERZ1 » Fri Aug 10, 2018 10:51 am
Clymer Manual states 1978 and later wet capacity (cc) 160, oil level with the spring removed fork fully extended 441mm sae 10w oil.
#3 PostAuthor: chrisu » Fri Aug 10, 2018 3:53 pm
i thought i'd answered - 180-188cc.
This is from the Kawasaki Z1000H manual
#4 PostAuthor: chrisu » Fri Aug 10, 2018 3:54 pm
i did answer it !!. And you replied !
senior moment ?
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Fri Aug 10, 2018 4:18 pm
you Did answer chris. you saved me replying. weird!!...
