Clutch release problem
MotoV4
This is going to be a tricky one to explain. My 82 Z1000J has lost the use of its clutch. I pulled in the lever to start it and suddenly it went slack. the cable is intact but it looks like the clutch release has flipped over. In the workshop manual it is shown as holding the cable at the bottom but mine now has the cable at the top, like it has flipped over somehow. i took the cable off and moved the clutch release lever to the bottom and tested it a few times on the third pull it flipped over again. Anyone else come across this ? Kind of hoping it turns out to be one of those common problems with a quick fix. Cheers
make sure you have plenty of slack in the cable. turn the middle cable adjuster fully to its minimum adjustment. then adjust the cable at the clutch lever ( handlebar) so the adjuster is about 10mm out. then set your clutch release lever in the correct position. the lever arm should be in the 8 o clock position looking at it from the back of the cover. replace the cover slacken the clutch release lock nut . unscrew the adjuster bolt + then turn back in until you feel some resistance. at this point turn it back half a turn in the opposite direction tighten the lock nut then put the required free play in the lever by adjusting the middle cable adjuster
As above plus; there is a flat cut off the side of the plate which holds the 3 bearings. Need to make sure it is indexed with the peg inside the housing. If it isnt the datum start point is half way through the adjustment range and you'll spend weeks fiddling inside the clutch.
From memory the adjuster screw under the rectanguler out cover is counter intuitive in its action. The above only applies if you dont have the helical spiral type of actuator.
MotoV4
Thanks for the responses I will check the cable, I have a new one coming so will aim to set it up as you described. I did adjust it before this happened so there is a possible cause there. I slacked the cable at the lever end as it was out a fair way and took up the slack on the barrel adjuster lower down on the frame. I will also check to see if mine is one of the spiral type actuators ( I think it is). Cheers
Re: Clutch release problem (revisited)
A revival of an old thread here due to what I think might be a similar problem? Your thoughts and advice would be much appreciated
Bought my '82 LTD 1000 last year but it's been sat doing sweet FA due to time and finances. I took her to get MOT'd yesterday and she passed with a couple of advisories.
On the way home I gave it a good blast up a long straight hill. 3/4 of the way up I noticed that the clutch lever had gone slack! I eased up and adjusted the cable at the lever on the move, which gave me back enough clutch to negotiate a couple of junctions before getting home.
I had to head out as soon as I got back and haven't yet been able to check the cable properly, or anything else yet. Any advice you can give me on what to look for or what this might be would be appreciated.
Chaz
Chaz
Barking Mad as always
1982 Z1000 LTD, running work in progress
Can you bring it round, and i will stare it into submission, either that or bore it into surrendering
Al wrote:Can you bring it round, and i will stare it into submission, either that or bore it into surrendering![]()
lol, it'd be nice to see you. When ave you got the time?
