Hi folks,
I'm going to remove the A4's carbs in the coming weeks as fuel has been leaking for a while which looks more like a dirty golden syrup under the float bowls - I think it's coming from perished O-rings in the drain screws but any common areas to look out for?
Anything to be aware of before I start?
Andrew
Removing A4 carbs
Removing A4 carbs
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- warren3200gt
Re: Removing A4 carbs
Just check the drain screw o rings before taking the carbs off. If it is leaking from the drain screws then taking the carbs off is a little excessive. Orange / golden syrup is evaporated modern fuel.
Short term fix if its o rings is a smear of silicon gasket goo around them before screwing back in. Leave over night to set before turning the tap on.
Thanks, got the O-rings, but the carbs they're looking pretty grubby so a decent degrease will do them good - just wondered if there was anything to be mindful of when taking them off.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- warren3200gt
Hardest bit is setting cables to the correct tension on re instalation which is eay to do. If your striping them down for a clean just ensure you keep the bits together for each carb.
Esso super premium unleaded petrol (97 + octane) does not contain ethanol, BP possibly not also. See their sites for more info. i tested the Esso fuel and no ethanol was there. Ethanol is what causes the problems on seals and sticky deposits. There is no legal requirement to add 5% ethanol to 97+ octane petrol.
In my experience, if they exhibiting goop on the outside then it's worth taking them off and looking in the float bowls to see if they need a clean. Use new float bowl gaskets, I recommend the Keyster ones (and their rebuild kits) as they are not made form card and I have never seen any of them leak after fitting.
But while you have the carbs out I'd recommend checking them thoroughly and setting them up.
Give me a shout if you get stuck.
Is it possible to remove all four float bowls with the carbs in-situ? just wondering because I have a slight leak from the bowl gasket on no.2 carb, and bowl screws in carb 3 could do with replacing with new ones - having to take the whole shebang out to get at/replace the one weepie gasket/four screws is maybe a task not worth doing until the carbs actually need a full strip n clean?
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
Done it loads of times,a small right handle ratchet with a cross head,plus a mirror and a piece of rag to catch the juice...Paul j
Thank you
well, there's the next job ...
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
Thanks for tips and advice folks - Paul, useful tip about the float bowls!
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
