Gpz1100b1 speedo options .
MrC
#1 PostAuthor: MrC » Fri Nov 09, 2018 8:07 am
I'm unable to use the electronic speedo pick up on the front wheel due to fork change has anyone used a pick up from say sproket ? Or what speedo options are you using . I would prefer to use std clocks but I'm open to other options.
Robw
Re: Gpz1100b1 speedo options .
#2 PostAuthor: Robw » Fri Nov 09, 2018 8:35 am
I have used Koso clocks, which the pickup can be on the wheel using a magnet. If you dont use your original clocks,I would be interested in buying them for my standard restoration.
Cheers Rob
MrC
#3 PostAuthor: MrC » Fri Nov 09, 2018 9:10 am
Thanks but I'm afraid all the std parts must stay as I'm trying to build it with an option to return to std if required..
Robw
#4 PostAuthor: Robw » Fri Nov 09, 2018 9:38 am
No probs, gpz 1100 a1 clocks work as well and i think they are cable driven
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Tue Nov 13, 2018 9:42 pm
what front front forks are you referring to? I'm assuming they come with a matching wheel.if it's a mechanical speedo drive from the front hub it should be a simple swap from the gpz1100 electronic set-up if you use a mechanically, eg cable driven speedo. if not it might be a headache.as mentioned earlier unitrack clocks work as they combine cable speedo drive with electronic rev counter and look nice lit-up of an evening..mark
Users browsing this forum: No registered users and 213 guests
