Z1000A2a Vacuum fuel tap
snowyz9
#1 PostAuthor: snowyz9 » Wed Dec 05, 2018 1:17 pm
Just developed a leak from just above the bottom outlet , i renewed the pipe on bottom , thinking it was that , and the top fuel out seems dry around , Question do these petcocks develope leaks behind where you turn the fuel to prime etc , and is a new petcock the only way to go , re age
Gus
Re: Z1000A2a Vacuum fuel tap
#2 PostAuthor: Gus » Wed Dec 05, 2018 1:26 pm
There is a replacement kit you can buy.
http://www.nrp-carbs.co.uk/shop/index.p ... ct_id=3132
Gus
"Set the GRINDER on it"
Users browsing this forum: No registered users and 102 guests
