CR Keihin 29mm carbs
stephen parr
#1 PostAuthor: stephen parr » Fri Dec 14, 2018 6:45 pm
Hi all, not been on for a while.
Does anyone on here know the basic setup for the above carbs please?
Need to know jet sizes & needle type with a standard 1015 motor.
Thankyou
Phil Churchett Award Winner 2012 (Z1R)
Phil Churchett Award Winner 2023 (Z1B)
PaulMceleney
Chunks
Re: CR Keihin 29mm carbs
#2 PostAuthor: PaulMceleney » Sat Dec 15, 2018 3:50 pm
Hi Steve I have most jets if you want i could come over to you and see what works best if this helps
stephen parr
#3 PostAuthor: stephen parr » Sat Dec 15, 2018 7:07 pm
Thanks for the offer Paul, but the carbs arn't mine, they're Geoff's mates in Lancs.
chrisw1
#4 PostAuthor: chrisw1 » Sun Dec 16, 2018 2:12 am
I have 29s on my 1015 motor ... 115 mains and it runs perfect
stephen parr
#5 PostAuthor: stephen parr » Mon Dec 17, 2018 11:22 am
Thanks very much Chris.
Big Fluff
#6 PostAuthor: Big Fluff » Mon Dec 17, 2018 3:01 pm
No, but "Hi Steve", great to see you're still around :D
Will
KWACKERZ1
#7 PostAuthor: KWACKERZ1 » Tue Dec 18, 2018 4:13 pm
From greg copes ape tuning guide.
CARBURETORS
Carburetors
For those of you running 29 smoothbores on a mildly modified street machine, here are some suggestions for carb modifications to give better mid-range performance:
# 20 Pilot Jets
# 0-4 Needle Jet
# 1.0 Air Jets
# 2.5 Needle & Set
* Float level heights, base of gasket to top of float 23.5 - 24.5mm
stephen parr
#8 PostAuthor: stephen parr » Tue Dec 18, 2018 6:55 pm
Big Fluff wrote:No, but "Hi Steve", great to see you're still around :D
Will
Thanks Will, hope to get back on the scene sometime next year.
stephen parr
#9 PostAuthor: stephen parr » Tue Dec 18, 2018 7:03 pm
KWACKERZ1 wrote:From greg copes ape tuning guide.
CARBURETORS
Carburetors
# 20 Pilot Jets
# 0-4 Needle Jet
# 1.0 Air Jets
# 2.5 Needle & Set
Thanks very much Phil, VERY informative!
