Hydraulic clutch conversion
scott
Junior Section leader
#1 PostAuthor: scott » Thu Dec 20, 2018 3:46 pm
Where can i get a hydraulic clutch for a Gpz1100b1??
Re: Hydraulic clutch conversion
#2 PostAuthor: ADRIAN H » Thu Dec 20, 2018 9:31 pm
mounting plate - and you'll need master and slave cylinders from ZXR750 + braided hose.
https://www.ebay.ie/itm/Hydraulic-Clutc ... 4d79729a2b
scott
#3 PostAuthor: scott » Fri Dec 21, 2018 9:00 am
Thanks Adrian, greatly appreciated.
scott
#4 PostAuthor: scott » Fri Dec 21, 2018 3:39 pm
Adrian, I have a zx7r slave cylinder. The slave cylinder pushes into a casting when fitting to a zx7r. Do I need this casting?
#5 PostAuthor: ADRIAN H » Fri Dec 21, 2018 5:41 pm
scott wrote:Adrian, I have a zx7r slave cylinder. The slave cylinder pushes into a casting when fitting to a zx7r. Do I need this casting?
I don’t think you will need the inner casing. When I fitted mine the slave cylinder fitted straight on the plate. Back face lined up perfectly with the clutch push rod. I had to cut the clutch push rod down by around 3-5mm.
scott
#6 PostAuthor: scott » Fri Dec 21, 2018 10:53 pm
Ok, thanks. That makes sense now.
scott
#7 PostAuthor: scott » Wed Jan 02, 2019 10:29 am
Adrian, i now need to source the hydraulic hose. Do you think one from a ZX7R or a ZRX1100 would be long enough?
#8 PostAuthor: ADRIAN H » Wed Jan 02, 2019 12:56 pm
I used a piece of stiff wire to gauge the length, ( I threaded mine over the top of the engine and down the back between the carbs), and placed a custom order for one made rom HEL. Can check length if you wish, having said this - I do have flat bars on my bike.
Kind regards Adrian
scott
#9 PostAuthor: scott » Wed Jan 02, 2019 1:34 pm
Thanks Adrian, i'll do the same.
Users browsing this forum: No registered users and 91 guests
