Z1000j ignition switch key number
Robw
#1 PostAuthor: Robw » Mon Jan 07, 2019 2:50 pm
I have had a look in search and still unsure about location of ignition switch key number. I have found a faint number on the switch housing 025-0U77, I dont think this is a key number. Do i have to remove the roll pins to gain access to the ignition barrel and thd number?
Cheers Rob
Re: Z1000j ignition switch key number
#2 PostAuthor: z1bman » Mon Jan 07, 2019 5:05 pm
the no is normally stamped very small where the pin for the steering lock exits the switch the no will start with a letter Z you will need a magnifier glass to read the no
Users browsing this forum: No registered users and 90 guests
