The speedo on my CSR only goes up to 80 / 90 MPH. Does anyone know what other speedos I can replace it with? I'd like to keep the same dimensions as the current clocks - just need the indications to go up to 140 / 160 MPH. Did Kawasaki stick with the same internal gearing ratio? The front wheel is 19 inches. Speedo is cable driven.
Cheers.
Z1000 M1 CSR Speedo swap info
- Dark Skies
KZ1000-M1 CSR
- london calling
- Dark Skies
london calling wrote:The CSR was an American only model,the LTD models had an electronic speedo.
Try a Z650 140MPH or Z900/Z1000 160MPH but they are a slightly different style.
Possibly try the Z750 LTD clocks
There's a Z1R clock going on ebay which look very similar in style - do you think the gearing might be out a tad though? I think the Z1Rs might have had an 18" wheel.
KZ1000-M1 CSR
- london calling
It won't make a LOT of difference, just read a tad higher, which has a 2-fold benefit,
1# Think your bikes faster than it really is
2# Make you slower/safer with the old speed camera's
I run 17" GSXR wheels with the standard clock, and it reads a fair bit higher, but no more than +10%
- Dark Skies
