Sprocket
King of Kings
Sprocket
#1 PostAuthor: King of Kings » Mon Jan 28, 2019 9:49 pm
Hey guys, any ideas apart from the usual on how to shift a MEGA tight engine sprocket nut? It’s not rust/corrosion as it’s brand new bike!
Re: Sprocket
#2 PostAuthor: Pigford » Tue Jan 29, 2019 7:22 am
Impact socket gun is the way to go + a bit of heat!
needaz1100r
Re: Sprocket
#3 PostAuthor: needaz1100r » Sat Feb 02, 2019 8:38 am
Pigford wrote:Impact socket gun is the way to go + a bit of heat!
Normally that is the way to go, (but there are socket guns and there are socket guns) but if it's a lock nut, or is fixed with loctite, sometimes all that happens is each impact just moves it a tiny bit and the loctite or locking whatever doesn't move and it springs back.
In that case, constant pressure from a long breaker bar is required.
Mark.
King of Kings
Re: Sprocket
#4 PostAuthor: King of Kings » Sat Feb 02, 2019 3:27 pm
Finally sorted, impact wrench and new socket, phew!
Users browsing this forum: No registered users and 94 guests
