took delivery of the Z1R from the US this week. I had noticed that it didn't have the spring loaded seat lock cover so i had order one in preparation.
Can anyone help with a picture from underneath of one that is installed.
The spring seems to be too long and although i can get it located over the cover spigot, tension the spring and lock it into the forked end of the spigot, when i compress it it just springs back out!
Can anyone help?
Z1R Seat lock cover
Z1R Seat lock cover
paid up member
Re: Z1R Seat lock cover
Hi rpeters
you have to insert the spring and close the two forks by bending them carefully! It's a one way ticket so do it correct the first time!
If you want to open the fork again one of the legs will probably break off...
Good luck
Good luck
do you have Tony Sculpher Z1R book page 139 Tail piece lock cover installation with pics on page 140
he says this not covered in any Kawasaki Manuals he has a step by step guide to how to do it
not sure i should post pic's of the page PM me if you need more help
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Thanks guys, also seem to be missing the air filter box under seat, any pics ? Or links?
Rob
Rob
paid up member
Hi Rob
do you mean the complete air filter box or only the silencer?
If it's the silencer, it looks the same as the one from a Z1000A1 or A2 or A3 ...
Pretty easy to find pictures on the web, just go for it.
first time i fitted one the thin bladed screwdriver i was using slipped & went straight through my hand sticking out the other side about 3 inches
z1bman wrote:first time i fitted one the thin bladed screwdriver i was using slipped & went straight through my hand sticking out the other side about 3 inches
Now that's a claim. ..
Hi Rob
take a look at this:
https://www.google.be/url?sa=i&source=i ... 8752447868
Hope it's clear for you.
