Next daft question oul coolers
Swirl
Re: Next daft question oul coolers
#16 PostAuthor: Swirl » Wed Jul 31, 2019 4:59 am
johny brando wrote:
Swirl wrote:
Mathh wrote:I always use a thermostat with an oil cooler. Oil that is too cold is as bad for an engine as oil that is too hot.
Can you buy a thermostat that goes inline say on the the banjo which only opens when the engine is up to temperature,
By-passe's can be / are good ........until the stat sticks or fails ( as they can do... either open or closed ! ) .........then it depends on how it's internal plumbing is designed - as to whether your top end gets 'enough' or any oil at all !!!!!!!!!!!
Thats why I choose to use use a mechanical means to restrict cooling air over my Cooler during winter months = a simple black Rubber blanking plate.... supported by 3 heavy gauge rubber bands... it's not very high tech but it works a treat & is not really visible when in place ! ( & it lives in my tail piece under the seat when not in use )
Got any pictures buddy
johny brando
#17 PostAuthor: johny brando » Wed Jul 31, 2019 11:04 pm
Don't know if this attachment pic will work ........?
#18 PostAuthor: Pigford » Thu Aug 01, 2019 9:53 am
Dunno about that - no criticism, but any oil flow restriction doesn’t sound healthy?
I just cover my cooler in lower temperatures.
I do have a thermostat but not using it as it’s a bulky bit of kit.
