Does anyone have a genuine Kawasaki manual which gives the correct standard fork spring length for:-
1978 Z1000A2 / Z1R (Z1000D1), KHI Part Number 44026-1003
and
1980 Z1R (Z1000D3), KHI Part Number 44026-1039
No guesses or assumptions please, and I don't need the lengths of any models other than those above.
I'm also after the length of the spacers from above the springs on a Z900A4 or Z1000A1, so if anyone has one lying around could you please measure it for me.
Thanks in advance
Fork Spring Lengths
I`m guessing that the spring free length is 521mm with a service limit of 511mm. That is for the 1000A1 with part No. 44026-071.
Don`t know what you mean about a spacer on top of the spring. Could it be they are aftermarket additions to increase spring compression ?
I had some of those on my LC back in the day !
I said no Guessing!!!
You are right about the part no. 44026-071 being used in the Z1000A1 and that part is also used in the Z900A4. In both cases the standard length of spring is 465 and a spacer is fitted above.
All I want to know (from a genuine kawasaki manual) is:
Z1000A2/Z1R(Z1000D1) spring length.
Z1R(Z1000D3) spring length.
Z900A4/Z1000A1 spacer length )part no. 44028-039.
Am I the only true anorak left?
Sweptail - thanks for the spacer info, 40mm makes sense as the Z900A4/Z1000A1 springs are 40mm shorter than the Z1A/Z1B springs which do not have a spacer.
TLC - Not sure that's the "D" that I'm looking for.
So I'm still after:-
1978 Z1000A1/Z1R (Z1000-D1)- these have the same springs.
1980 Z1R (Z1000-D3)
Thanks guys
1980 Z1R (Z1000-D3)
Thanks guys
- Mikekilbride
- Regular Poster
Re: Fork Spring Lengths
Hi I know this is a old post but does anybody out there know the correct length of 1972 Z1 fork springs?
This old GIT keeping the old "kawi's" rolling 5 x Z1's. 3 x 72' H2's. 2 x 73' H2's. 2 x 74 H1's. 1 x 71 H1. 1 x W1 and finally 2 x 69' A7SS
- 8 Valve Mark
495.5mm (485mm service limit) according to the factory manual.
- Mikekilbride
- Regular Poster
Thanks for this I'll check them out. M7 72 Z1 is so difficult to get on the centre stand as I think there's wey too much sag (About 2 ")
Users browsing this forum: Google [Bot] and 123 guests
