Good Afternoon All,
I have just purchased a Z1000 rear hub (minus the sprocket carrier and cush rubbers) and I’ve inherited a small problem ! Has anyone had any experience in removing the steel spoke carrying saucer that is fitted on one side of this hub please ? The hub is a very useable but it’s a scabby thing and requires a very good clean up, the saucer is rusty, slightly pitted and has the chrome peeling off in some areas. So I really need to split these items if at all possible. So far I have tried pressing with a small amount of heat and all to no avail, I can’t imagine that it’s threaded unless of course you know different. Many thanks.
Z1000 A1 Rear hub.
Re: Z1000 A1 Rear hub.
Eddie Scarlett knows someone who provides this service.
Prob’ best not to try yourself ?
It’s a press fitting almost impossible to remove.
There is a bike custom business which built the blue z1000 with the nickel plated frame which is on ebay for 15.5k item number 123848223131 they built a tool for removing the chrome spoke disc.
Users browsing this forum: No registered users and 94 guests
