Z1 Carb parts
RBY
Z1 Carb parts
#1 PostAuthor: RBY » Mon Aug 12, 2019 10:19 pm
On the last legs with my Z1 resto and working on the carbs - VM28SC's coded 1473. Have stripped them down and had vapor blasted and now looking to replace the felt washers on the linkage shaft (4) and on the individual slide lever assy's (4 total). For the life of me I can't pin these down on the parts diagrams. Can anyone help with part numbers for these and where I might get replacements? Probably also need new rubber dust plates, 16055-002
Re: Z1 Carb parts
#2 PostAuthor: Philippe » Tue Aug 13, 2019 10:44 am
Hi RBY
as far as I know these were not sold seperately...you can try to make them yourself from a felt foil with two hollow pipes.
Don't expect good results from the first attempt! It's possible with some exercise.
Good luck
Re: Z1 Carb parts
#3 PostAuthor: ZedHead » Tue Aug 13, 2019 11:50 am
Keyster do them with the bushes around £40 ex VAT and postage for a full set
Re: Z1 Carb parts
#4 PostAuthor: ADRIAN H » Tue Aug 13, 2019 7:54 pm
Talk to Ben Day, VapourWorx - he may know of a source. Very helpful chap.
Users browsing this forum: No registered users and 94 guests
