Ring compressor
King of Kings
Ring compressor
Hey guys, what’s the current weapon of choice for holding rings together while lowering barrel into place, or is it best to use Kawasaki OE tool?
Re: Ring compressor
3" drain pipe and cable ties are a cheap alternative
Re: Ring compressor
ZedHead wrote:3" drain pipe and cable ties are a cheap alternative
which is what i use - together with the home made piston holding brackets to keep the pistons level.
