Gents,
Can anyone tell me whether the injectors on the GPz1100B1/B2 and the ZX1100A are the same or different?
Thanks in advance.
Gary.
Fuel injectors.
Re: Fuel injectors.
The injectors on the ZX1100A’s have part No 49033-1001
According to the CMS website https://www.cmsnl.com/products/injector-fuel_490331001/ this part was fitted to KZ1000G1, KZ1100B1/2 and all the ZX1100A’s
A2 1979-80. A1 1980-now
Re: Fuel injectors.
they all use the same part
Re: Fuel injectors.
Not cheap are they ! (I presume that price is for 1, not a set of 4)
I've often thought it might be nice to have a go at restoring a fuel-injected bike, but now I'm not so sure.
H2B GPZ900R
Julian_Boolean
Re: Fuel injectors.
Holy crap, 318 euros per injector, a set of Mikuni flat slides is a lot cheaper than that, if you want CV carbs Z1000J ones fit, if you want modern CV carbs I think Suzuki GSXR/Bandit ones fit with a firm push (the spacing is slightly different)
Re: Fuel injectors.
I've got a few spare sets.
If you've got the original ones and you think they might be blocked get a car garage to run them through a bosch injector cleaner.
Re: Fuel injectors.
I had the injectors off my GSX14 cleaned and refurb by these guys. Found them to be bang on. They supplied a graph of before and after performace of th injectors and also gave me new filters and 'o' rings. They were fast on turnaround and cheap too
http://injectortune.co.uk/
Re: Fuel injectors.
Thanks gents.
I've used Injectortune in the past for my 1100 Uni and found them to be spot on.
I have a spare set of injectors, I was recently looking at a B1 that was on carbs and wondered if they'd fit but it's been sold.
Gary.
Gary.
