Fuel pipe
- warren3200gt
Re: Fuel pipe
Here you go Snowy, fill yer boots at a fraction of the cost.
https://www.advancedfluidsolutions.co.u ... r-90-c.asp
Re: Fuel pipe
Snowy, in the past I've also used some hose from Z Power and its gone rigid before fitted my tank on
- was only used a couple of times from my auxilliary petrol tank - now thrown it in the bin.
Since changed to Nitrile (NBR) - its meant to be far more resistant, and does seem better.
Cheers Tim
Cheers Tim
Re: Fuel pipe
Warren did you get the 6mm , comes out 5.4mm
Re: Fuel pipe
Warren , did you use the 6mm , 5.4 real
- warren3200gt
Re: Fuel pipe
Cant recall mate. I bought 5m of several sizes as its cheap, as I seem never to have a length of syphon hose when I need it!
Fraction of the cost for overflow pipes.
Re: Fuel pipe
Thanks Warren , fuel pipes great and fast post from your guy.. 7.2 I'd was perfect
- warren3200gt
