Afternoon Men.
Has anybody actually found a set of dual air filters to fit the Mikuni BS34 carbs as I'm struggling to find an exact fit?
These are what I think are the closest but not sure if the 54mm flang ID will be big enough.
https://www.knfilters.co.uk/rc-2382-uni ... air-filter
Don't want to spend 100 to find they don't
Any enlightenment would be greatly appreciated, links etc.
Gus
Mikuni BS34 Dual air filters.
"Set the GRINDER on it"
Julian_Boolean
Re: Mikuni BS34 Dual air filters.
Surely you can just measure your carbs?
But 54mm sounds right.
I have measured my carbs and they are nearer to 56mm
Julian_Boolean
Pretty sure I used 54mm filters on BS34s in the past, I don't remember them being a tight fit but I don't have the BS34s anymore, though I do have the Ram Air filters still.
Your centre to centre measurement is the most important thing, 75mm, the collars are malleable so will stretch a little to suit a slightly larger carb mouth.
Thanks for the replies.
Much appreciated
Gus
Much appreciated
Gus
Users browsing this forum: No registered users and 89 guests
