Front sprocket cover
Robw
#1 PostAuthor: Robw » Thu Mar 19, 2020 9:22 pm
I have a cover that came with a gpz1100b1 engine, but when you try to fit to the engine in the gpz1100 b1 frame, the lower right corner hits the frame. That corner is more square than a J or gpz one, also the gear lever pivot and mount are closer together than on the j I have had it ceracoated and new seals fitted, so i am abit miffed. Anyone have any ideas what it originally came off?
Rob
8 Valve Mark
Re: Front sprocket cover
#2 PostAuthor: 8 Valve Mark » Thu Mar 19, 2020 9:57 pm
maybe a z1000 mk2 rob?
Robw
#3 PostAuthor: Robw » Thu Mar 19, 2020 10:05 pm
I will have a look.
Cheers Rob
popsA1
#4 PostAuthor: popsA1 » Fri Mar 20, 2020 3:33 am
It sounds like a Unitrak cover to me. The pic, I believe, is an 1100B cover. If the gear linkage hanger is directly below the gear position numbers as I’ve drawn and there’s the bit to the lower right corner, it could well be from an 1100A. If it is I would be interested in it. I have a couple of B covers if you want. Not as good as this one. But B covers are more common.
PM me if you’re interested.
A2 1979-80. A1 1980-now
Robw
#5 PostAuthor: Robw » Fri Mar 20, 2020 6:41 am
You have pm
Users browsing this forum: Kev1R and 83 guests
