Z900A4 Snapped chain - Casing damage
NickH
#1 PostAuthor: NickH » Thu Apr 23, 2020 4:44 pm
Sooo - just after finishing my restoration (the chain looked new as do the sprockets!) on a little ride out for my, er "essential groceries" - I have a snapped chain. as you might expect, there's damage to the inner casing around the front sprocket.
The top section of this casting has been ripped off, and also a portion of the upper back section, which exposes a few holes that look like they're channels for securing bolts.
I was considering not bothering to replace this casing, however, one of the holes to the upper left (which I assumed to be a bolt recess, but there's no thread inside it, and none of the outer casing bolts align with it - so it's like a clutch pushrod hole, without the pushrod!)
Ordinarily, I wouldn't worry about this, but on running the engine, oil pisses out of this hole. So, a partial success, then.
So - does anyone know
a) What this 5mm hole is
b) Whether I can just seal it off (I cannot see what function it performs - seems just an empty channel.)
c) If it's possible to get a replacement inner casing - the one that goes behind the front sprocket. In my Kawasaki manual, it's referred to as an "External shift mechanism cover"
I assume these covers are like rocking horse shit, due to machine age, and 40 odd years of snapped chain damage to the original stock.
All suggestions welcome - thank you guys.
Nick
Re: Z900A4 Snapped chain - Casing damage
#2 PostAuthor: warren3200gt » Thu Apr 23, 2020 5:34 pm
If its the cover I think your describing its called a mission cover and readily available ( at a cost ) on flea bay.
https://www.ebay.co.uk/itm/Kawasaki-Z1- ... 2656581792
compo z1r
#3 PostAuthor: compo z1r » Thu Apr 23, 2020 6:52 pm
Replacement casing is must but I’d be more bothered y the chain let go ? Summit must b out of line ? Or a really poor chain !!! Or sprocket
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
rickm
#4 PostAuthor: rickm » Fri Apr 24, 2020 9:19 am
As above, I'd want to know why the chain let go in the first place.
H2B GPZ900R
#5 PostAuthor: Pigford » Fri Apr 24, 2020 9:48 am
warren3200gt wrote:If its the cover I think your describing its called a mission cover and readily available ( at a cost ) on flea bay.
Shouldn't that be TRANSMISSION ?
#6 PostAuthor: warren3200gt » Fri Apr 24, 2020 4:16 pm
:hah! You would think but no! Everyone, calls them mission cases.
NickH
#7 PostAuthor: NickH » Sat Apr 25, 2020 11:28 am
Thanks everyone - I'll get the sprocket alignment checked and get that replacement from eBay
Cheers guys :-)
compo z1r
#8 PostAuthor: compo z1r » Sat Apr 25, 2020 1:40 pm
NickH wrote:Thanks everyone - I'll get the sprocket alignment checked and get that replacement from eBay
Cheers guys :-)
Make sure there’s no play up front or Cush drive back it’s alignment is right get a new chain too and not too tight as well u don’t need another casing after this one :shock:
#9 PostAuthor: Philippe » Sat Apr 25, 2020 4:03 pm
Hi Nick
maybe a stupid question: is the master link riveted or can you open the link by removing the little closing clip ( "fish")?
If the master link is removable mind the direction of the closing clip, the closed portion has be installed in the direction of the chain movement, not the other way !
