Engine mount nut
Adrian90s
Engine mount nut
#1 PostAuthor: Adrian90s » Fri Jul 03, 2020 10:26 am
the pointy engine mount nut on my bike was loose, the top bolt on the 3-way mount bracket under the engine. I've nipped it up, should it be tight, or does the tab float?
Thanks Z1 by the way
wilsonsjw11
Re: Engine mount nut
#2 PostAuthor: wilsonsjw11 » Fri Jul 03, 2020 10:50 am
Tight and torqued up.
Regards
Steve
Adrian90s
#3 PostAuthor: Adrian90s » Fri Jul 03, 2020 5:10 pm
Thanks for that...thats all the reply I need
Ady
#4 PostAuthor: Philippe » Sat Jul 04, 2020 3:58 am
Hi Ady
the correct torque is 4 kg/m.
Adrian90s
#5 PostAuthor: Adrian90s » Sat Jul 04, 2020 6:32 am
Thanks Phillippe
