As title I need to work out a few bits and pieces re the Motion Pro PPT.
Does the new housing just butt up against the current switchgear?
What length is the new twistgrip? Other threads advise it's likely to be a tight fit!
Or are there any other options that people have used?
Stu
Z1000R2 Elr push pull throttle for RS34'S
Re: Z1000R2 Elr push pull throttle for RS34'S
Mine is about 7 years old but is a Motion Pro PPT.
The cable drum is 24mm along the bars and overall length sits currently at 144mm. The twistgrip sleeve is shorter than the rubber grip by 5mm but i may have cut that down.
Therefore fitted length as it stands is 144 plus the 5mm overhang of the rubber grip making 149mm along the bars. I did have a DR400 one before that but it was near identical.
Have not had it fitted to bars with switchgear and a mastercylinder so cant comment about available space sorry.
Thanks very much, I'll order one and give it a go.
Stu
Stu
