Long hose
Long hose
If the brake hose from the handle bar master cylinder to the "T" joint on the bottom yoke is a bit long and winds its way a bit round the clocks and headlight area till it reaches the "T" joint can this cause problems with bleeding the brakes?
If you get fliud out of the calipers the lines shouldn't be holding air, banjo's, splitters, bolts, master cylinder and calipers may be but not usually the lines. If you have an overly long line see if you can have the banjo pointing up from the m/cylinder - it makes bleeding easier.
