'78 z1R question about Ballast Resistors
Cwiseguy
#1 PostAuthor: Cwiseguy » Fri Oct 09, 2020 4:59 pm
Hello Team:
I have recently upgraded to Accel 3 Ohm coils/wires and a Dyna-S ignition. I get two different opinions. One is to remove (loopback) the two Ballast resistors? One is to leave them alone?
Does anyone know for sure?
Both the '78 and the '80 model z1R have these Ballast Resistors. The '78 model had factory points. The '80 model had factory CDI.
Thanks.......CwiseGUY
Re: '78 z1R question about Ballast Resistors
#2 PostAuthor: warren3200gt » Fri Oct 09, 2020 10:03 pm
This what google has to say about it.
"Is a ballast resistor necessary?
And while ignition coil life may be compromised without a resistor, the additional secondary voltage (at the spark plug) is increased which generally improves power. So does your application require a ballast resistor? Quite simply, if your ignition has breaker points the answer is yes; if not, the answer is no"
#3 PostAuthor: chrisu » Sat Oct 10, 2020 7:03 am
3 ohm coils?
Bin it
KeithZ1R
#4 PostAuthor: KeithZ1R » Sat Oct 10, 2020 7:07 am
With 3 ohm coils, it aint necessary, put it on one side or bin it
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
steve452
#5 PostAuthor: steve452 » Sat Oct 10, 2020 11:40 am
Interesting explanation regarding BR's here
https://www.randakksblog.com/ballast-re ... components.
Specific to the Hobnail GL1000 and references the Lead Boot but offers useful info on testing etc if you must have one.
Z1-B, 360bhp ZX1000NGF
Cwiseguy
#6 PostAuthor: Cwiseguy » Sat Oct 10, 2020 1:20 pm
chrisu wrote:3 ohm coils?
Bin it
Yes, 3 Ohm Accel coils.
Thanks. Cwise
Cwiseguy
#7 PostAuthor: Cwiseguy » Sat Oct 10, 2020 1:25 pm
steve452 wrote:Interesting explanation regarding BR's here
Thanks, I read that.
ANyway, the thing is this (twin) resistor is not attached in the circuit to the coils themselves. The schematic has them going through the lighting. They are called Ballast Relay Regulator Resistors.
I notice some of the other schematics, kz1300 for instance have a resistor in the circuit with the coils.
Of course, all a bikes wiring trickles over to a COMPLETE circuit.
Thanks, Cwise
Cwiseguy
#8 PostAuthor: Cwiseguy » Sat Oct 10, 2020 6:12 pm
warren3200gt wrote:This what google has to say about it.
Thanks for the info, Cwise
Cwiseguy
#9 PostAuthor: Cwiseguy » Sat Oct 10, 2020 6:13 pm
KeithZ1R wrote:With 3 ohm coils, it aint necessary, put it on one side or bin it
Thanks...Cwise
