Will Z1000 Ltd 1980 calipers fit my Z1000A2
#16 PostAuthor: Pigford » Tue Apr 08, 2008 7:20 pm
The CSR (early '80's) has leading axels... :??
Big John
#17 PostAuthor: Big John » Tue Apr 08, 2008 8:50 pm
Ian, got 2 LTD's (B2's) at the moment, according to the Z-Power parts book the front calipers are the same on the A1's and B1's. The A2's and B2's have a different part number but I'm pretty sure the fork legs can be swapped around to suit.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
Padders
#18 PostAuthor: Padders » Tue Apr 08, 2008 8:52 pm
Cheers John.
2 Ltds being a bit greedy there :D
Big John
#19 PostAuthor: Big John » Tue Apr 08, 2008 9:07 pm
I know Ian, had an ebay moment,I was going to modify the first the one but it was stock apart from the K&N's seemed a shame to spoil it and the second one came at the right price with A2 body kit, Harris etc.
mikey
#20 PostAuthor: mikey » Tue Apr 08, 2008 9:22 pm
Padders dont!! put caustic soda on them calipers get it wrong and theyl fizz away to nothing if you want them polished leave them as they are and ill strip them with a proper anodising stripper.
Padders
#21 PostAuthor: Padders » Tue Apr 08, 2008 10:15 pm
Ok Mikey if I can get them to fit I'll be in touch.
#22 PostAuthor: paul doran » Wed Apr 09, 2008 4:10 pm
Rich wrote:Piggy you're guessing again! I don't know how you ever got those spanners but I hope no-one followed you advice !!!!
STs had forward mounted axle, Mk2s "normal" forks and Ian will be making up mounting plates if he wants to use those calipers.
rich has your measure right enough Piglet your a bluffer or should that be an old duffer :lol: :lol:
