Z1000 right switch cluster
Gavin
#1 PostAuthor: Gavin » Wed Feb 10, 2021 1:23 am
Hi all,
I have a new loom for the mk2 and it has the plug set up for a Uk /EU right hand switch, mine is a US style, does anyone supply repo Z1000 switches that will just plug in
Gavin
Z1000 MK2
Z1300 DFI
Re: Z1000 right switch cluster
#2 PostAuthor: z1bman » Wed Feb 10, 2021 12:27 pm
you can buy the block connectors from bikers toolbox
https://www.bikerstoolbox.co.uk/acatalo ... ctors.html
Gavin
#3 PostAuthor: Gavin » Wed Feb 10, 2021 7:44 pm
Cheers for the info, but my switch being from the USA doesn’t have the lights on and off switch therefore no wires to put into a plug
Z1000 MK2
Z1300 DFI
#4 PostAuthor: z1bman » Wed Feb 10, 2021 8:03 pm
if its not a us spec harness you can use the european switches from z power https://www.z-power.co.uk/switch-gear-s ... -z900-pair
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Thu Feb 11, 2021 12:34 am
pretty sure that I'll have a spare uk/euro switch Gavin, I'll check later n let you know. m
Gavin
#6 PostAuthor: Gavin » Thu Feb 11, 2021 5:50 pm
Cheers Mark, appreciated
Z1000 MK2
Z1300 DFI
