Can anyone tell me the thickness of the foam that the clocks sit on, also is there a particular type I should be getting or will neoprene do.
Gavin
Speedo and tacho foam
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: Speedo and tacho foam
I searched old posts but I think it got lost in the great database wipe.
I had some foam from a supplier in High Wycombe which I made into several kits and then gave away.
I think I have a little left but not cut to size. As far as I remember it was 6mm Toshiba foam. Buggered if I can find it now.
Found it.
Let me know if you or anyone else wants some.
Yes please. I couldn’t believe the state of mine when I last looked.
I’ve been hoping to find something suitable for some time.
A2 1979-80. A1 1980-now
I am also in the market for some
Remember your original post now
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
I would take some too for my 1100ST, same as 1000J clocks. They do move even though nuts are tight, might solve it.
1981 Z1100ST
2003 ZZR1200
1999 4.6 Range Rover P38
1925 Marshall S Type Steam Roller
Previous Zeds: 1000J Pip Higham special, GPZ750 unitrack, Z650B and one non-Zed ZZR600
2003 ZZR1200
- 8 Valve Mark
BJ81ZED wrote:I would take some too for my 1100ST, same as 1000J clocks. They do move even though nuts are tight, might solve it.
the J clocks are designed to have a bit of "suspension" to protect the electronics from vibration. bloody annoying, but true.
Users browsing this forum: Robw and 68 guests
