J motor into an early frame
I am sure this has been done a few times . Just asking if a J motor needs much work or what is needed to fit in an A1 frame . Thanks
Re: J motor into an early frame
Yes it can be done, the length is very similar and it will go.
Some people only use the one front mount of the J but personally I would add a lower front engine mount to the frame as the J has two.
KWACKERZ1 wrote:Yes it can be done, the length is very similar and it will go.
Thanks.
Users browsing this forum: No registered users and 116 guests
