Does anyone remember those holts touch-up paints? Kinda tubes with a built-in brush. I've managed to take a chip out of the top of my tank, and wondered if there's a match / known code for the Z900A4 bottle green. I figured it was quite a common colour, so just wondered if anyone knew of something I could use to fill in this in with.
Thank you :-)
Touch-up paints
Re: Touch-up paints
A good auto factors should be able to mix a touch up kit, IF you have the correct code or RAL.
- warren3200gt
Re: Touch-up paints
Take a panel and get a supplier to scan it a mix a paint. Paint doesn't stay the same colour, it fades over time, so even if you knew the colour code fresh paint wouldn't match.
Re: Touch-up paints
RS Bike paint will have the correct paint for your Z900.
https://www.rsbikepaint.com/en-gb/colours.php
Re: Touch-up paints
NickH wrote:Does anyone remember those holts touch-up paints? Kinda tubes with a built-in brush. I've managed to take a chip out of the top of my tank, and wondered if there's a match / known code for the Z900A4 bottle green. I figured it was quite a common colour, so just wondered if anyone knew of something I could use to fill in this in with.
Thank you :-)
Colour is Called Diamond Dark Green. Available as a touch up spray or pen via the above.
Re: Touch-up paints
Excellent - thanks very much Garry :-)
Users browsing this forum: No registered users and 118 guests
