Would anyone have a source for the black pan head GPZ fairing Screws?.
I can find plenty of aftermarket Hex head type but nothing like the original Phillips (JIS) ones.
Not bothered if they are the gen Kawasaki type, just something in the style of the originals.
Pan heads are 15mm across..
TIA
Fairing Screws?....
Fairing Screws?....
- warren3200gt
Re: Fairing Screws?....
Skidmarx?
Have u been online to cmsnl got originals for z1r there !!
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
I'll have a butchers - Cheers.
I checked the part numbers I see on the labels on these items and they are still available at your dealer. And cheaper than from CMSNL as is the postage.
Most people don't know factories have lots of small items still for sale, think of screws , bolts, nuts, gaskets, rubber parts, carb parts and so on.. Only downside can be that items can be superseded be more modern ones or from another model, so not for people that want a 100% correct looking bike. But for carb parts for instance you get better quality than what is on sale through Ebay (although the last ones are cheaper).
What I normally do is check the CMSNL site for part numbers and order these at a dealer. That saves them the bother to look op numbers.
"Set the GRINDER on it"
Gus wrote:https://www.kawasakioriginalparts.com/part_search?partnumber=220C0512
Gus
Cheers Gus.
Already tried that but when I put the part number in from the Fish ( 92009 ) the search shows a different screw.
Sorry.
Link amended.
My bad picked the wrong screw. (from a B1 B2 model)
https://www.kawasakioriginalparts.com/p ... 92009-1654
Seems to be different parts between the GPZ1100A1 and A2
The 92009 is a drawing reference number and not the actual part number.
Google 92009-1654
Gus
Link amended.
Google 92009-1654
Gus
92009-1654 in stock at cradley 26 pence each
z1bman wrote:92009-1654 in stock at cradley 26 pence each
Cheers Bud.
