I'm not sure where I should post this, if its in the wrong place I'm sure someone will move it.
I'll looking to get white plugs made up for the H'bars on the ELR, I cannot find any at a reasonable price on the net. probably in nylon but I'm open to suggestions. Are any of you interested in a set if I get some made? I will only be looking for cost plus postage.
Also If anyone has genuine plugs... any chance you could give the length of the shoulder before the curve? Otherwise all other dimensions are same as the OD and ID of the bars I would think.
P
ELR Bar ends
Re: ELR Bar ends
Hi Mark
I have the old bars of my Z1000R, I'll take some pictures and give you the dimensions of the white handlebar ends .
Re: ELR Bar ends
Hi Mark
some pictures of the handlebar ends and dimensions
the diameter of the plastic /nylon end (20,85 mm) is a bit less than the outside diameter of the handlebar itself
the lenght of the straight end is approx. 8 mm
I hope you can do something with this.
Re: ELR Bar ends
Philippe wrote:Hi Mark
Hi Philippe,
Thanks for taking the time. I would have guessed the shoulder was about 12mm, great to get the correct dimensions.
P
