Coil confusion
Gus
Coil confusion
#1 PostAuthor: Gus » Thu Mar 31, 2022 4:42 pm
Looking for a set of coils to use on the MK2 style transistorised ignition system.
Am I right in thinking I need 1.5 Ohm coils.
Does anybody know an aftermarket supplier of said coils with a 90mm mounting pitch?
Gus.
"Set the GRINDER on it"
Re: Coil confusion
#2 PostAuthor: Philippe » Fri Apr 01, 2022 9:09 am
Hi Gus
have a look at these:
https://www.z-power.co.uk/z1000a3a4b3b4 ... 000-models
just ask if they will fit your bike.
KeithZ1R
Re: Coil confusion
#3 PostAuthor: KeithZ1R » Fri Apr 01, 2022 10:09 am
Gus I ditched the Ballast resistor and put green3 ohm Dyna's on mine and it has run faultlessly, so there is no good reason not to use the chinese Dyna copies :!:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Robw
Re: Coil confusion
#4 PostAuthor: Robw » Fri Apr 01, 2022 10:30 am
Try Grumpy 1260 for the coils, he tends to have them in stock.
07774924067.
Rob
Re: Coil confusion
#5 PostAuthor: chrisu » Fri Apr 01, 2022 11:07 am
wemoto.com sell them also.
check whether they're 90mm or 100mm centres.
Gus
Re: Coil confusion
#6 PostAuthor: Gus » Fri Apr 01, 2022 11:40 am
Thanks for the replies and leads guys.
After thinking last night my next question was going to be could I ditch the resistor.
Cheers again.
Gus
